Menu disappears when hovering in IE
Thread begun 8/25/2010 11:57 am by lee341019 | Last modified 8/26/2010 6:55 am by Jason Byrnes | 2407 views | 3 replies |
lee341019
I have just been testing a new menu and every time I test in IE7 or in Compatability mode in IE8, the sub menus disappear.
When you hover over the menu, you can see the sub items, but as you go to hover over them, they disappear. Any Ideas?
I have used this on aastra-telecom.uk.com as a test.
If you hover over 'Handsets' you will see the problem.
Any help would be great!
the issue is occurring because you have set the width for the level 1 menu items to auto.
you must specify a width in pixels for the menu to function correctly in IE.
lee341019
Thank you so much, that was driving me crazy! The only thing I have had to do is set up more css (level1wide) to enable me to have a wider menu off one menu item.
Thanks again for your help.
Glad to hear it is working.
