Problem with DFP2
Thread begun 6/07/2009 12:09 pm by mustang_sally_85344510 | Last modified 6/08/2009 10:01 am by mustang_sally_85344510 | 4933 views | 7 replies |
Problem with DFP2
Hello,
I have had nothing but problems since I upgraded from DFP to DFP2. My site upload was working great. And I decided to upgrade to be able to resize uploaded images. I have had numerous errors. ...
WHITE SPACE....
AND HERE IS THE LAST ERROR.
Fatal error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 3296 bytes) in C:\apachefriends\xampp\htdocs\bt4u\WA_DigitalFilePro\HelperPHP.php on line 823
Is there any video tutorials on this I have followed step by step instructions, and my site is a mess now.
What do you suggest?
Thank you in advance for your help!
another error message
So, I took a brand new copy of a page that (used to work) and just opened and closed it after the newly installed DFP2...tested the page and here is the error message.
Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING in C:\apachefriends\xampp\htdocs\bt4u\centerinput.php on line 17
Are we suppose to change the bindings? or WHAT ? :( :(
Please post a support incident and include your phone number. We will need to have an engineer work with you to reproduce and debug this issue.
Submitted ticket but have an addition ?
When I look in the bindings area....I have the original WA Upload files, (which I originally binded server file name to), and also I have bindings available to me in the form field areas also.? Which should this be binded to?
The errors are with the WA Upload files bindings.
So, on my insert and/or update pages. I should bind them to the lightening bolt in the form field area? :)
I think you will need someone to work with you directly. Please post a support incident.
thank you :)
Thank you...and yes I did submit a ticket, just wanted to maybe fix it before 2-3 days... Under a time gun right now..! But thank you again, you are always such a great help!
