adding ssl without messing things up
Thread began 8/13/2010 8:16 am by watercolor346374 | Last modified 9/02/2010 1:21 pm by Jason Byrnes | 2798 views | 11 replies |
watercolor346374
I need to do the following:
From the cart page when the customer clicks checkout I want the check out page to be checkout.php. Then when they fill out the form they will go to the confirm which I want as an https page. Is there anything special that I need to do in the coding? I assume that this will change my wacart folder and that will have to be reuploaded...anything else to look out for?
Thank you
all you need to do is change the checkout behavior on the cart page to point to:
chakout.php
watercolor346374
ssl
So, I do that in my ecart object and then make sure I upload the files that pertain to the ssl and the waCart folder? Will I have to reset the buttons?
nothing changes in the cart object, only in the cart.php page.
watercolor346374
ssl
I went into my behaviors on my detail page, changed the button add to cart to:
cart.php
I have the site in test under karenshotz.com/test/ filename
After I changed the redirect for the button, I saved the file then I went back in to the button behavior and it had not changed...it was still cart.php
Also, is there any code that I need to add to the pages indicating the https? How does the button know the page is https?
the change should not be done on the detail page.
it should be done on the cart page.
on the cart page, double click on the eCart Checkout server behavior.
Set the checkout button redirect to the https address to the cart page.
SSL has no bearing on the page itself, only on the port used to access the page.
watercolor346374
ssl
do I need to do this on the checkout, and confirm pages? I tried to do it on the checkout page so that when the checkout button is checked, the confirm is ssl. There was not button behavior.
no, you only need to change the cart page.
watercolor346374
ssl
Hi Jason,
I have several times, gone into the cart.php page put the full address in for my ssl, uploaded the page and it continues to stay in the http format...I go and check the page in dreamweaver and the behavior is back to checkout.php.
Thank you
the code for the checkout redirect will loook like:
//WA eCart Redirect Check Out
if (isset($_POST["WA_Store_Cart_Checkout"]) || isset($_POST["WA_Store_Cart_Checkout_x"]))     {
$Redirect_redirStr="checkout.php";
  if (
$Redirect_redirStr != "")     {
    if (isset(
$_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "")     {
      if (
strpos($Redirect_redirStr"?") < 0)     {
$Redirect_redirStr .= "?".$_SERVER['QUERY_STRING'];
      else     {
$Redirect_redirStr .= "&".$_SERVER['QUERY_STRING'];
$WA_Store_Cart->redirStr $Redirect_redirStr;
$WA_Store_Cart->cartAction "Checkout";
once you find this code block, locate the following line:
and add the https url.
