Problem finding PATH TO PEAR
Thread begun 8/02/2010 4:14 pm by pablo412301 | Last modified 2/14/2012 6:57 am by Jason Byrnes | 8691 views | 17 replies |
pablo412301
Hi;
UE4 doesnt send mails and I cant figure why...
I tested PEAR on my server and seems to be fine as it says on:
installation.checking.php
My server gave me: "bool(true)" (you can see it here: pear_test.php )
Then I tested php_info.php and the include_path is:
.;C:\Program Files\Parallels\Plesk\Additional\PleskPHP5\pear;./includes;./pear
First of all Im not sure what to put in PATH TO PEAR
Can you give an example on how it should look like?
looks like the path to pear should be:
C:\Program Files\Parallels\Plesk\Additional\PleskPHP5\pear\
pablo412301
I put that path , but nothing happened. Still not getting any mails to be sent from the form
I'm using WIN2008 + PLESK , so I don't know if this affects the path or what
The form I want to send is in contacto.php
You can see the phpinfo is in: php_info.php
and the pear test in pear_test.php
Any clue of what I'm doing wrong? what do you need to check why it doesnt work?
I need this to be working as soon as possible
you have the forms action set to post to another page:
<form id="form1" name="form1" method="post" action="c_gracias.php">
change the forms action to post to itself.
<form id="form1" name="form1" method="post" action="">
you can set universal email to forward to the c_gracias.php page after the email is sent.
pablo412301
Thanks, I did that and the results where:
Warning: require_once(C:\Program Files\Parallels\Plesk\Additional\PleskPHP5\pear\Mail.php) [function.require-once]: failed to open stream: No such file or directory in E:\inetpub\vhosts\magiadeluco.com\subdomains\test\httpdocs\webassist\email\PEAR_Mail_using_SMTP_php.php on line 115
Fatal error: require_once() [function.require]: Failed opening required 'C:\Program Files\Parallels\Plesk\Additional\PleskPHP5\pear\Mail.php' (include_path='.;C:\Program Files\Parallels\Plesk\Additional\PleskPHP5\pear;./includes;./pear') in E:\inetpub\vhosts\magiadeluco.com\subdomains\test\httpdocs\webassist\email\PEAR_Mail_using_SMTP_php.php on line 115
Any other idea that may help to solve this problem?
Is this on your own personal server? Or a hosted server?
If it is a hosted server, you should confirm with them that the Pear Mail package is installed, and check with them what the correct path to pear should be.
The base Pear install does not always contain the Pear Mail package:
Mail
pablo412301
This is our company server
What do you recommend me to do? download and install it again?
Pablo
if the Pear Mail package was not installed to begin with it will need to be installed
Since it is your company server, what do you see when you browse to:
pablo412301
Yes; you were correct
Nothing like MAIL there
So?
Just download and unpack the package on download (1.2.0) there?
yes that is the Pear mail package to install.
