Cross Site Scripting issues
Thread begun 7/30/2010 2:46 pm by webassist2366041 | Last modified 8/05/2010 8:36 am by Ray Borduin | 7662 views | 12 replies |
webassist2366041
I created forms for the upload of files and for the processing of credit cards. They have been in place since last year and have not been changed except for text changes.
Our site has passed security compliance scans by SecurityMetrics.com during that time until this week when it failed.
SecurityMetrics techs said that there was cross site scripting problems on on pages, such as this one:
manuscript_submission.html. He said to make sure that our host was sanitizing all user input for html code. Characters : < > / \ ? = ' and "
I sent that information to our host. Their tech support said that it was a problem that must be solved by the web designer -- i.e., me -- and that they didn't support third-party programs.
Our merchant account is in jeopardy because we are now non-compliant and fees have begun to accrue.
I even removed that page to see if it would pass (which it didn't), but there are other pages that have the same problem. I will put it back up after I finish this message so that you can see it.
I don't know if the following is related or it's a different problem. When opening a page, I got this error:
JavaScript error while loading WA eCart AdvCo.htm: At line 746 of the file "Macintosh HD:Applications:Adobe Dreamweaver CS3:Configeration:Shared:Controls:Scripts:WATrigger.js": ReferenceError: WA_getDocumentDOM is not defined
Another page had this error: While executing analyzeServerBehavior in WA eCart AdvCo.htm, a JavaScript error occurred.
Both of these might have absolutely nothing to do with the non-compliance issue.
As soon as I send this message to you, I'll put the page mentioned above back online so that you can see it.
Please help us.
webassist2366041
Addendum to Last Message Re First Data
I put the page back up.
The SECOND error that I mentioned before was for this page:
checkout-design.php
Those might just be errors that have nothing to do with the cross site scripting.
I moved this post to a new thread as it does not seem to be related to the linkpoint checkout or any updates to it.
Can you post back with the page in question in a zip archive as well as any other page that was flagged in the audit. It seems that if there were a couple of extra checks in place on these pages to ensure that nothing other than the expected values can be used you would not be getting these failures.
webassist2366041
Requested Pages
Here are two of the pages that failed.
webassist2366041
The PDF of the Failed Scan
This post has been deleted.
Cross site scripting security holes open when you display a value from a form directly without encoding characters... particularly "<" and ">", which could be used by a cross site scripting hack to run javascript or other code.
Of the two pages you sent... one is corrupt and I can't read it, and the other is the form itself. The cross site scripting vulnerability would actually be exposed and fixed on the action page of that form. The form itself looks fine, cross site scripting is about what you do with the results of the form, not problems with the form itself.
webassist2366041
I have no idea what you mean.
I'm told the following by the security compliance tech.
The request string used to detect this flaw was:
/bookstore/iwas/?<script>cross_site_scripting.nasl</script>
The output was :
HTTP/1.1 200 OK
Date: Sun, 01 Aug 2010 16:09:59 GMT
Server: Apache mod_fcgid/2.3.5 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
Set-Cookie: PHPSESSID=7297c80b054a9bdd89abf3d134038e37; path=/
Keep-Alive: timeout=5, max=100
Connection: Keep-Alive
Transfer-Encoding: chunked
Content-Type: text/html
Following is the location of the script in the source code. This is the cross site scripting vulnerability. This is an example and may not be limited simply to this page.
<!-- InstanceBeginEditable name="body" --> <table width="628" border="1" align="center" cellpadding="0" cellspacing="2" bordercolor="#000000" background="../images/backgrounds/bg-tan-sponge.gif">
<tr>
<td width="628" align="center" valign="top"><form name="WA_eCartBooks_Display" method="POST" action="/bookstore/iwas/index.php?<script>cross_site_scripting.nasl</script>">
<table width="370" cellspacing="0" border="0" cellpadding="5" class="S3C_QuickCartLayout">
<tr>
Please help me. I'm traveling in the dark. What do I do in non-technical terms?
update the form action on the page:
just set the action to: "/bookstore/iwas/index.php"
webassist2366041
I opened the page /bookstore/iwas/index.php.
I looked at the action field.
It says:
<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>
On the Server Behaviors tab, it says: Dynamic Attribute (and the information above).
I don't know what to do.
Remove that, and just set the action to: "/bookstore/iwas/index.php"
that should fix the problem.
