Empty Session Variables with Ecart 4.5.2
Thread begun 7/26/2010 4:36 am by kp006274029 | Last modified 8/09/2010 12:23 pm by Eric Mittman | 5028 views | 9 replies |
kp006274029
I'm using ecart 4.5.2 with PHP 5.2 (running on windows server 2003 web edition as testing server) for some reason when I use an add to cart button to add a product to the cart page; It creates an empty session file on the server, so when you goto the cart page the cart is seen as empty.
If I create a two test pages in PHP create a session variable on one and echo it on the other test page, this works fine and a non-empty session variable is created on the server.
Any help greatly appricated.
KP
When you are configuring the eCart object you have a choice of using sessions or cookies to store the cart info. Do you have sessions set for this value? Have you tried uploading these files to a live server to see if you have the same result? If you have your cart set to use sessions and you can confirm that sessions are working on your server then the cart should retain it's contents while the session is active. Do you have the cart page set as the redirect in the add to cart server behavior? If so you should be going directly to this page, is this when you see the cart without anything in it? Please post back with all of the detail that you can about this and include a copy of the add to cart page, your cart display page, and the WA_eCart folder from your site root in a zip archive. I will take a look at your pages locally.
kp006274029
Hi Eric,
I can confirm that (1) The eCart object is set to store in sessions (2) Press a Add to Cart button creates a empty session file in the sessions folder (3) I've uploaded onto a live server and it works fine (4) Sessions appear to be working fine, i.e. I can create a session variable called test set it to "hello" an echo it onto another page, it also creates a file with the value in it on the testing server. (5) The cart page is set as the redirect in the add to cart behaviour, after being redirected on the testing server the cart is empty.
I've added the zip file as requested, also included my php.ini file just in case you can spot something in it that could be causing the issue.
I'm using PHP version 2.2.13, Also getting the following in the php error log:
[29-Jul-2010 13:27:12] PHP Warning: PHP Startup: Unable to load dynamic library 'C:\Program Files\PHP\ext\php_mssql.dll' - The specified module could not be found.
in Unknown on line 0.
Don't understand why it can't be found considering it is in the specified directory.
Many Thanks
KP
When I test your files I'm able to add items to the cart without issue so it seems to me that there might be a session management issue on your server. To help you test the sessions more thoroughly you should add in this code on the pages you are testing so that you can see exactly what is in the session during each step.
if(!session_id()) session_start();
print(
"<pre>");
var_dump($_SESSION);
print(
"</pre>");
This code will print out the entire session so that you can see all of the values in it. You should add this to your pages then test the site locally and test it again on the live server. Let us know what the differences are between the servers in the results that you get.
kp006274029
Hi Eric,
I placed the code at the start of the onlineshop.php and the cart.php files.
It returned the following: array(0) {
At the top of both pages on the testing server.
On the live server the onlineshop.php page displays:
array(2) {
["trulydelicious_Items"]=>
string(98) "0|WAECART|choc|WAECART||WAECART|0|WAECART|1|WAECART|2.99|WAECART|0|WAECART|2.99|WAECART|1 choc (0)"
["WAEC_ContinueRedirect"]=>
string(20) "/test/onlineshop.php"
If I click the add to cart button it displays the above message with the following warning on the onlineshop.php page
Warning: Cannot modify header information - headers already sent by (output started at /home/t/r/trulydelicious/public_html/test/onlineshop.php:3) in /home/t/r/trulydelicious/public_html/test/onlineshop.php on line 44
I also did the same with sessiontest1.php and sessiontest2.php with the following results:
***Live Server***
sessiontest1.php
array(0) {
sessiontest2.php
array(1) {
["test"]=>
string(5) "hello"
**Testing Server***
sessiontest1.php
array(0) {
sessiontest2.php
array(1) {
["test"]=>
string(5) "hello"
KP
Thanks for posting back with the results. This tells me that you have a session handling problem on your local testing server. I'm not sure what the problem could be since you are able to get a good result with the session testing script. If you remove this code from the pages on the live server they should work without error, make sure to not leave any blank space or returns outside of the php blocks, doing so could cause the same error to occur.
kp006274029
Thanks for the help Eric, I've solved the problem. :)
Glad to hear that, was it a session setting on your local testing server that needed to be adjusted?
kp006274029
Hi Eric,
I never did discover the reason, I just gave up and re-installed the entire server and it worked 1st time.
Best Wishes,
KP
Ok, that is good to know. Glad it is working out for you now.
