System Not Working Online
Thread begun 7/24/2010 7:13 am by hbibizadeh396670 | Last modified 7/26/2010 3:28 pm by Jason Byrnes | 3089 views | 5 replies |
hbibizadeh396670
I have created a complete User Registration System using Security Assist and CSS Form Builder.
When I test it locally it seems to work fine.
But when I test it online, it does not work.
When I click register, the page just seems to go blank. I don’t know what the issue is but I will provide a link below so you can see for yourself.
users_Registration.php
When a PHP page displays blank, it means a php error has occurred, but error reporting is not enabled on the web server.
Add the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
hbibizadeh396670
After adding the script to the Registration page, I get these errors
Notice: Undefined variable: database_Connection in /customers/ashperfectimage.com/ashperfectimage.com/httpd.www/user_login/Templates/users_Registration.php on line 40
Notice: Undefined variable: Connection in /customers/ashperfectimage.com/ashperfectimage.com/httpd.www/user_login/Templates/users_Registration.php on line 40
Warning: mysql_select_db() expects parameter 2 to be resource, null given in /customers/ashperfectimage.com/ashperfectimage.com/httpd.www/user_login/Templates/users_Registration.php on line 40
Notice: Undefined variable: Connection in /customers/ashperfectimage.com/ashperfectimage.com/httpd.www/user_login/Templates/users_Registration.php on line 41
Warning: mysql_query() expects parameter 2 to be resource, null given in /customers/ashperfectimage.com/ashperfectimage.com/httpd.www/user_login/Templates/users_Registration.php on line 41
please send a copy of your users_Registration.php page.
hbibizadeh396670
I have attached a copy of the system. Again the system works locally, but not online for some reason. The pages are in the templates folder.
it looks like you have not modified the connections/database.php file with the correct information to make a connection to the remote mySQL server.
You will need to modify the database connection server to properly connect to your hosts mysql server.
