Problem after installation
Thread begun 7/23/2010 6:11 pm by Dynalux | Last modified 8/02/2010 10:26 am by Eric Mittman | 1965 views | 3 replies |
Dynalux
I just completed the installation successfully, all green ticks and database created.
Now I'd like to start by adding a page, but when I click on CONTENT and I chose a page name, you can not see the menu.
When i login and click the green + icon and enter the name of the content page / area (Home Page) and then click add the pop up closes and page refeshes but with no new content area in the left colum
I can not do anything, thank you for helping me.
Do you have any screen shots that you can post back with so that we have a visual reference for the issue you are experiencing? One thing you should try is reloading the files except for the connection folder. Leave the connection folder on the server then re-upload all of the other files to ensure that it is not a problem with the files not being there. If you continue to have this problem please post back and include some screen shots so we can see what you are getting.
Dynalux
Here is a picture but it does not add much because nothing happens !
Unable to add content, I tried to upload with CuteFTP (instead of Dreamweaver), but it changes nothing ...
In advance thank you for your help.
Thanks for the screen shot, it helps. I have had another report of something very similar and it turned out to be a problem with the files. When you uploaded again did you do so with a new set of files that you downloaded? If not you should try uploading the files again via ftp after you download a fresh new set. If you still have these problems let us know and I will ensure that a ticket is opened up for you.
