File manipulation image upload
Thread begun 7/13/2010 11:17 pm by victor405909 | Last modified 7/14/2010 10:30 am by Jason Byrnes | 1573 views | 1 replies |
victor405909
I am having problem inserting image file to database.
I have Universal Mail I assume File Manipulation is from this particular extension.
I have started creating pages for admin directory following PDF from webassist (i.e. Adding Digital File Pro to DataAssist Insert and Update Pages).
Whilst following PDF it refers to using Digital File Pro upload I do not have this option I did however locate the File Manipulation upload feature. I finished the wizard and find on product insert text is inserted into columns in database with no problems. However image for product chosen via browse function on form is not loaded nor any path to image file inserted.
What am I doing wrong?
Have you updated the insert record server behavior?
You need to update the insert record server behavior, and change the binding for the file column to use the WA Uploaded files (File Field Name) -> server File Name instead of the binding from the form collection.
If you are still having difficulty, please send a copy of the page so I can examine the code.
victor405909
This post has been deleted.
