Subscriptions
Thread begun 7/06/2010 11:12 am by i.edwards384429 | Last modified 7/07/2010 12:08 pm by Eric Mittman | 1738 views | 1 replies |
i.edwards384429
Subscriptions
Hi
at the last stages of a project which has been to say the least a bit of a learning curve.
What I have is a list of models in a database and a list of Photographers in the same database.
The photographers search via various criteria and are shown images from the models portfolio.
With only one problem left on that side ( awating a response from techies) I can now progress onto the next stage,
Simply there are two groups who need to pay an annual charge for use of the site. so only two products to sell
My untutored PHp/mysql thought was to allow access to the site by use of a logical field ie yes for subscribed and no for not.
Thought (dangerous I know) that I could arrange a payment using powerstore/ecart ( only have ecart4) so that when the payment is confirmed the database would be updated to reflect the payment. I was thinking of controling the subscription time by using a count option ie <365.
Ok thats my logic, is there an easier way or can I not do this is the way I think?
Not sure whether to struggle on or pay someone to do this last bit.
Any advise very welcome
thanks
Ian
I wanted to respond to your post to let you know that eCart does not support subscription or recurring payments so that would have to be worked out as a custom part of the checkout. If you are trying to manually determine when to charge again I think it would be best to work with timestamps and make use of the mktime and date functions to allow you to manipulate values for comparing the dates. One thing you could do would be to add a year to the current time then when you are checking it you would just compare to the current time, if the date is equal to or less than the current time then it has passed already.
