DataAssist Javascript and Wizard Errors
Thread began 7/03/2010 2:36 pm by tige247759 | Last modified 7/06/2010 8:21 am by Jason Byrnes | 2038 views | 1 replies |
tige247759
I am using DataAssist to create an db admin console using ASP. When I choose show all records from the recordset paging options, it doesnt seem to recognize that, and then, when I go to create the pages, I get a plethora of javascript errors such as this:
The Move To First Record script does not define the findServerBehaviors function
The Move To Previous Record script does not define the findServerBehaviors function
The Move To Next Record script does not define the findServerBehaviors function
The Move To Last Record script does not define the findServerBehaviors function
The Show If RS Is Not Empty script does not define the findServerBehaviors function
and so on and so forth for a set of buttons I didnt want in there in the first place. And then, whenever I go to edit or upload the page, the scripts need to prompt me again to remind me of these errors.
Can an admin tell me what the bleep is going on here and how do I fix it.
I am using version 2.0.5
TC
try uninstalling version 2.0.5 and installing the newer version 2.0.7 that is available from the download center.
also, delete the Dreamweaver cache file from the users configuration folder:
If you are still having problems, please provide some additional details:
What version of Dreamweaver are you using?
What OS are you using?
