Weight Units
Thread begun 7/03/2010 1:47 pm by ross360115 | Last modified 7/07/2010 12:20 pm by ross360115 | 2188 views | 4 replies |
ross360115
Weight Units
Hi
I am changing the weight units used in PowerStore to kg’s . I have changed oz to kg in the eCart object, the lbs labels in the Admin/Product_Update.php and Admin/product_Insert.php. However when a site wide search is performed, many instances of lbs are found. Could you please let me know which instances of lbs or oz, I would need to address?
Thanks in advance!
we do not support changing the weight units.
The most important place you will need to change this is in the shipping code on the confirm and pp_confirm page.
look for code similar to:
$Shipping_PackageArray[$Shipping_PackageIndex]["WeightUnits"] = "LBS";
ross360115
Thank you! So I take it I just ignore all the lbs, mentioned in the WA_eCart_Definition_PHP.php file?
yes, do not change anything in the WA_eCart_Definition_PHP.php file.
ross360115
Thank you!
