Mail.php Missing (UE 4.0.1)
Thread begun 6/30/2010 6:36 pm by kevin347925 | Last modified 7/02/2010 3:06 pm by Eric Mittman | 3863 views | 4 replies |
kevin347925
When trying to send an email from my webpage, I get the following error.
Warning: require_once(Mail.php) [function.require-once]: failed to open stream: No such file or directory in ...webassist/email/PEAR_Mail_using_SMTP_php.php on line 115
Fatal error: require_once() [function.require]: Failed opening required 'Mail.php' (include_path='...') in .../webassist/email/PEAR_Mail_using_SMTP_php.php on line 115
I'm sure that this is probably a quick fix, but I'm not sure where to go from here.
I am using UE 4.0.1
Thanks so much.
This file should be created by the Universal Email server behavior and be present in your local site. Was this file skipped on upload? Check the local site to see if it is in the location specified and if it is not you should create a new page and try applying Universal Email to this new page. Applying the server behavior should create the file for you that you can then upload to your server. Please give this a try and let us know if there are any further problems.
kevin347925
I uploaded the entire webassist folder, and the Mail.php file is not located in the local site folder.
I ran the UE behavior multiple times with no luck.
kevin347925
FYI, in running tests on completely new pages, I found that the assigned redirect was not working. Instead of going to the redirect page, the page remains blank--no error messages.
Finally, when I test UE on a completely new page, Mail.php does not populate.
You should try renaming the configuration folder to undo any corruption that might be present in your current install. Here is a link to the instructions for this:
showpost.php?p=12293&postcount=2
Once you go through the steps and remove the currently installed extensions then re-install Universal Email please test it out and let us know if the issue persists.
