problems getting site sculptor to work
Thread begun 6/28/2010 7:14 pm by dsteele55973 | Last modified 7/01/2010 5:04 pm by Jimmy Wu | 4939 views | 11 replies |
dsteele55973
I purchased “Site Sculptor” and installed it via extension manager, However when I clicked the create new site sculptor site, via the Web assist button on Dreamweaver cs5 v.11, a notice appeared informing me I needed to create a new blank page before we could continue (this I did) after clicking again to start a new “Site Sculptor site a blank interface appeared, it had Site Sculptor on the top left so we were, where we need to be, but it stopped there and nothing else happened, (I think a list of site templates should have appeared) after a while I checked using Task Manager and was informed the programs where not responding and I had to close them down
From the common Installation Issues I Went in and removed the “Winfilecashe.data” file, when attempting a new site again, the following had not happened in previous attempts, a Web Assist sign appeared confirming a valid license/serial number but at this point the programs again stopped responding, I uninstalled and reinstalled the extension, then again removed the “Winfilecashe.data” but the same result as previous it confirmed the valid license but stopped responding at that point.
Your assistance in finding out what is wrong and putting me on the correct path would be much appreciated.
Regards Dave Steele.
Jimmy Wu
It seems that the step to validate your serial number on our activation server is causing the issue. The connection may be being blocked and waiting for a response. Do you have any security, virus scan or firewall software set up that may be blocking this activation connection?
dsteele55973
problems getting site sculptor to start
hi,
I do have a firewall and Zonealarm installed, if this is the problem please explain what I need to do to work around it and get the program up and running, and what needs to be done to ensure the problem will not happen again should I need to close down the anti virus and firewall to complete the task
regards dave steele.
dsteele55973
addition to above
hi,
further to above entry, your system did acknowledge a valid serial number and only then did the programs stop responding and had to be closed.
Jimmy Wu
Can you try disabling the security and firewall software before running the activation again to see if that was the cause of the error?
dsteele55973
hi,
Closed down firewall and zone alarm and tried to start "site sculptor" again, unfortunately with the same no response problem after being informed serial number was valid.
dsteele55973
tried the following
hi,
I tried to install the following extensions to see how they reacted, e-bay site builder and tools for Google, uploaded via the extension manager, closed Dream weaver as instructed when trying to restart dream weaver, nothing happened it would not load, there seems to be a conflict there somewhere, your advice please.
this_is_me
Try installing from within Dreamweaver
I had similar issues. Uninstalled it through Extension Manager. Then opened Dreamweaver CS5, Commands->Manage Extension. Installed it from here and everything worked fine...
dsteele55973
hi,
uninstalled the extensions, however when downloading site sculptor again it auto starts up ex. manager installs via there and loads the webassist button into dreamweaver, I was not able to install via the commands button. any other ideas
Jimmy Wu
Are you saving the mxp file to disk or just opening it from the website? Try saving it to your hard drive and then running it the way this_is_me is outlining.
