Can not log into CMS with password
Thread begun 6/26/2010 6:58 am by david165365 | Last modified 6/27/2010 8:54 pm by neilo | 2669 views | 3 replies |
david165365
I uploaded site sculpture files on to server, have database set up, was asked to set password and username. I then tried to log into CMS using the password & username and it does not work. I do not get an error message. It comes back to the login page. Should I delete the database and start over or is it a different problem?
The website appears fine. I just can not access the cms to make changes.
Would appreciate any help. Thanks.
neilo
Hi David,
Before doing that, it would be worth accessing the CMS database, selecting the wa_settings table and browsing it for your admin_username and admin_password values, just to make sure they are present and correct (rows 6 & 7 under 'value').
david165365
I checked the wa_settings and the admin password and username are both listed in the values.
Now what should I do?
neilo
Hi David,
(While waiting for the WA_TECHS to return on Monday):
Is this a fresh first install? Or are you installing on top of a previous install?
Also could you check out Eric's post #3 on this thread about session handling and perform the test mentioned therein on your remote server, and post back the reults?
