Problems uploading image - UE
Thread begun 6/23/2010 3:05 am by David Stringer | Last modified 6/28/2010 7:30 am by Jason Byrnes | 3848 views | 6 replies |
David StringerBeta Tester
I cannot manage to upload images to my web server. I have done so in the past, using DFP and this is still working today. I am using the same web server, but a different website on this occasion.
As far as I can see, I have set the same criteria, i.e. directory permissions etc.
The url is form.php
Any help would be appreciated!
David
Solved
As usual - had missed one little point. Had included a directory too many!
Attention to detail, that's the answer!
David
Great, glad to hear you have this working.
designgraphic
Cannot Upload files...
Hi there! I am having a similar problem.
Yesterday the upload process worked. Today... not.
The form posts the file name correctly to the database but the image does not upload.
I also remember from yesterday that it doesn't remembers the image name when using the update page and I had to reupload when I was updating a record.
I am uploading the Update file to check.
for file upload to work, the forms encoding type must be set to multipart/form-data. change the form tag to:
<form  action="tblNews_Update.php?intNewID=<?php echo(rawurlencode($row_WADAtblNews['intNewID'])); ?>" method="post" enctype="multipart/form-data" name="WADAUpdateForm" id="WADAUpdateForm">
for the update page to function properly, you need to create a hidden form element, set the value of the hidden form element to use the value that is in the recordset.
in the uplaod file behavior, set the default value option to use the hidden form element.
this is covered in detail in the "Applying File Upload to DataAssist Insert and Update pages" how to on the universal email support page:
universal-email/
designgraphic
Thank you once more.
Thank you Jason. I am now starting to get productive. It took some time to get used to the procedure...
I must say that the extensions are great once you get used to them.
Glad to hear it is working.
