passing cart in url ?
Thread begun 6/16/2010 1:18 pm by mustang_sally_85344510 | Last modified 6/22/2010 2:23 pm by Jimmy Wu | 1887 views | 3 replies |
Was wondering if there is a tutorial somewhere on how to at the add to cart information to an existing link button?
Jimmy Wu
There is no tutorial on how to do this, but if you add an add to cart button to a blank page, you can see what code is added and emulate that code to modify the existing button to work as an add to cart button.
So I have image with a link
for example:
cart.php
how do i add the variables to the end of the link? is it possible?
cart.php?
thank you in advance :)
Jimmy Wu
Did you try applying the add to cart to a blank page and take a look at what is applied? You will have to have a form with the button in it and additional code to write out the query string.
I can't see your pages, because your links are using localhost, which is only a local server to you.
