Require_once or include form file problems
Thread begun 6/16/2010 8:58 am by Miguel | Last modified 6/16/2010 4:41 pm by Eric Mittman | 2350 views | 3 replies |
Miguel
Hello im making a website where i need to have a right bar where i display a subscribe to newsletter form and will have a bunch of other stuff, i made the right bar with all the links and repeat regions necesary at the end i added a css form with css from builder, now when i include this file to template or the pages that will have the right bar with
<?php include ('rightBar.php'); ?>
when i test the page im getting
html:
Warning:  session_start() [function.session-start]:  Cannot send session cache limiter - headers already sent (output  started at C:\xampp\htdocs\life\blogs.php:143) in C:\xampp\htdocs\life\WA_ValidationToolkit\WAVT_ValidatedForm_PHP.php  on line 3
But when i test it wihtout that it works fine, mi goal here is to use css form builder to insert data to a user table field that want to get news from the site, im also planing to have this form in an ajax so it will not reload the hole page when submited.
My first question is how can i prevent the warning msg should i move the <?php require_once("WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
to the main page and edit something and what should i edit on the form?
And is it posible to accomplish my goals and is there any pointer or tutorial that can tell me how i can do this?
Im kind in emergency hoping the response
Sades
Do you have this code on line 143 in your blogs.php page? If so the error seems to be saying that there is output occurring on this line. You should look at the beginning and end of this line for any white space characters or returns to see if this is causing the output.
If the output has already occurred by the time to you get to this line regardless then it would be a good idea to link to the include files at the top of the page before any output occurs. You would need to make sure to adjust the paths accordingly.
Miguel
Yes i have it on that page and no theres no blank space triple checked for blank spaces between php tags always
Ok, you should try adding the require once lines from the included page to the top of your page that you are getting the error on. You will need to make sure that you adjust the paths in the require once code to match the location of the files referenced.
