Update Record UE file field resize
Thread began 6/11/2010 11:46 am by contact318852 | Last modified 6/11/2010 2:40 pm by Eric Mittman | 1212 views | 3 replies |
contact318852
hi I upgraded to Universal Email from Digital File Upload and have created a data assist insert, update page set.
I then added a file upload field to the insert, and update pages.
Everyhting is working as expected with the exception of the image resize options on the update page 'upload files server behavior' when I click to step two the resize options are not selectable. I have manually entered the resize options but they do not take effect.
Resize options work ok on the insert page, but an not be altered through the wizzard or manually on the update page, And the update page does in fact upload the image and adjust the database entry accordingly.
When you say that you are not able to edit these settings in the interface what happens for you? A screen shot might help to show what the problem is. Also, you say that you have tried to update these settings manually on the page? What happens when you do this? If you can please post back with this info and the page in question so we can get a better idea of what is occurring.
contact318852
Thanks for your prompt reply.
I have resolved the issue - I restarted my computer, and repeated the steps from a backed up page and this time it worked.
If the issue should reoccour I will try to detail the steps to repeat the issue
Ok, thanks for posting back and letting us know, update us if you see it again.
