PHP not working properly with column on cart
Thread began 6/10/2010 11:09 am by chriscaldwell11357847 | Last modified 6/10/2010 12:15 pm by Jimmy Wu | 706 views | 1 replies |
I am not sure where to post this, since my previous post apparently is lost in a thread that went from one topic to another, and therefore is not getting looked at perhaps.
I have my site set up, and all the php code validates, the html validates, etc. I created a static cart, and added a column for two items I'm selling that allow a person to specify which country or city they want printed on their t-shirt. This is selectable from a list. I followed the same procedure to set this custom Location column up as I did when setting up the Size column. However, something's not working. When someone selects a size, it shows up perfectly in the cart, but the location they choose doesn't display.
If I have to pay for upgraded support, no problem. All pertinent php code, etc. is attached. Ps. Since I took the screen capture, I changed the ID to an integer (it no longer is ilsat073, but just 073.
cartphp5.zip
shirtphp.zip
Jimmy Wu
Your previous thread wasn't forgotten about, but you won't necessarily get responses right away when you post. I answered your other thread here:
showthread.php?t=13467
We can continue to work on the issue there if what I told you didn't work.
