newbie question - how to edit checkout info
Thread begun 6/04/2010 7:33 am by question382438 | Last modified 6/04/2010 10:34 am by Jimmy Wu | 1645 views | 1 replies |
question382438
I just purchased ecart and I'm a bit overwhelmed with the installation. My apologizes for such a simple question...how do I edit a current checkout info and details?
I was successful in creating the checkout webpage. However, now I need to make changes to it. Is there a way to edit the info that has already been inputted? or does ecart require that I go through the entire checkout wizard?
TIA.
Jimmy Wu
You can modify specific parts of the setup by going into the server behaviors panel. If you're unfamiliar with the server behaviors, you should probably run through the wizard again.
