Using Theme-It on a Published site!
Thread begun 6/02/2010 7:36 am by dennis372614 | Last modified 6/02/2010 1:47 pm by Jimmy Wu | 2153 views | 1 replies |
dennis372614
What is the best way to edit a Power Store 3 site that is already published.
Using Dreamweaver and Theme-It.
Do I have to export the MySql database from the published site to my local testing server?
I tried downloading the published site and defining in Dreamweaver, and editing with Theme-It
however upon uploading back, the CSS is not updated in other pages.?
I am so totally confused with this. with the Database connection I know needs to be edited for the local testing server, but then the databases are different?
If just starting out and you first setup Power Store 3 locally, And complete the site.
How do you upload to Publish at ISP? SInce databases will need to be created?
I wish Web Assist would address this for Power Store 3 and Theme-It and now Sculpture.
How to using Dreamweaver with a site already defined.
What specifically needs to be changed, when editing from ISP to your local testing server.
Having a You-Tube tutorial would be extremely helpful.
Example. FTP the site to your local testing server in Xaamp. Define site in Dreamweaver, which we should already know how, then edit the connection .php for local connection.
Export your MySql database from your Published site, then Import to local database.
Seeing all this step by step would save us lots of time and minimize tech support issues.
I know its covered somewhere, but searching throughout the Forums is time consuming.
Jimmy Wu
If you want the css to be propogated to all the files, you will need to apply the template in Dreamweaver and then upload all the modified pages. If you make changes to a template and then upload just the template, the changes will not be applied to the pages that are based on the template.
I would recommend making a backup copy of the database and the site files before making any changes.
You can either download all the files and apply the changes, and upload the files and see how they look by testing there or as you said, download all the files, and import the database and change the connection file and test on a local machine.
PowerStore is meant for deploying on a server and getting it all installed there with minimal hassle, so that is why there is no directions for copying between two different servers.
