Site definition causes error in some WebAssist products
Thread begun 5/29/2010 6:11 am by esms | Last modified 10/18/2010 5:24 am by gtltaa413199 | 8161 views | 15 replies |
esmsBeta Tester
Hello,
Bought 'Site Sculptor' this morning but it won't run. I had a similar problem last week with another WA program. This was resolved by WA providing some new js code (I think).
Can this be done again please for SS?
Please see screenshots for errors.
Jimmy Wu
I am opening a backend ticket to take a look at this issue with you. We have been unable to reproduce this bug. To check your backend ticket, log in to your account at www.webassist.com and check your support history.
esmsBeta Tester
Thanks - I'll check now.
Jimmy Wu
We were able to determine the issue having to do with a site being defined in CS4 and the same site then being defined in CS5.
A workaround is to add a testing server to the site definition. This will update the site variables to be stored in the way CS5 is looking for them.
toms016390756
Thanks Jimmy!
pictorys391664
I have the same problem with site sculptor and menu write on CS5 which I downloaded July 31,2010.
Both extension do not load and cause run time error, please help.
you also posted this issue in another thread:
showthread.php?t=14296
see my reply there.
pictorys391664
Yeh, same problem as menu writer, the extension doesn't load.
Here's the screen shot
login.php
mtdunham75
I'm having the exact same problem. What's the fix?
