Problems with PowerGallery
Thread begun 5/26/2010 9:48 am by larisse148343 | Last modified 5/26/2010 2:03 pm by Eric Mittman | 1399 views | 1 replies |
larisse148343
I am hoping to get some help with my PowerGallery setup. One of the problems I had was that the links in the admin area were not working properly, but I think I resolved this by changing the links in the menu.php file. However, I am still having problems with changing gallery names or adding new galleries. In the case of the changing the names, I get a failed pop-up dialogue box. When I attempt to add a new gallery, it goes through the motions, but no new gallery shows up.
I am able to add new images, but the tags and information do not seem to be stored. I am unable to save any changes in the Manage Images section including adding titles and descriptions and moving the order of the pictures. Changes will not save.
Also, I am not able change the design. Nothing happens when I click the apply area. The default remains. Also, I've noticed that the previews are having some problems, as well. They don't seem to be displaying the way they should.
I have checked my permissions both to the database and the files. They seem to be correct. I do believe that my webhost prevents me from having my files as 0777 since I get a 500 server error when I attempt to change them.
In fact, I have installed PowerGallery twice. Once with the folder name changed to powergallery, and once name changed to a more site specific name. I made sure all changes were affected throughout the files in the code for the file paths.
I use FireFTP to upload all files.
The installation always seems to go fine, but using the PowerGallery fails. I do love using Webassist products, but I am starting to feel as if I've wasted my money. I don't want this to be the case. I was very excited to be able to use this product on my sites. I hope someone can help me so that I can in the future. Thank you.
I have seen a couple of the issues you are describing in regards to not being able to update the order of the images or the descriptions. When I have seen this issue before it had to do with how the information was entered. What have you called your gallery and what are some of the image names that you have? Where you able to create the gallery and add images? If so at what point were you not able to add any more images?
The information that I have seen that causes these problems is usually cut and pasted from another text file, or special characters are used in the text. Please post back with any details you can about this so we can investigate further.
