Error with CS5
Thread begun 5/26/2010 6:33 am by victor367017 | Last modified 8/23/2010 6:58 am by Jason Byrnes | 3835 views | 6 replies |
victor367017
Error with CS5
When I go to change a menu using CS5 I get an error after I change the content. After I make the change and I try to save it I get the following Dreamweaver error
Error generating mneu (wa.generate.menu)
TypeError: this.orientations[orientation] has no properities
victor367017
Error with CS5
When I try to clear the cache and follow your instructions I see that there are three sets of Dreamweaver in the appdata section. Dreamweaver, Dreamweaver cs4, and Dreamweaver cs5.
There are no DATA nor keys under Dreamweaver, There was an older wincache under Dreamweaver CS4 (I upgraded from that and Adobe did not delete the old keys and data), and Dreamweaver CS5 has no wincache but it does have a siteCache.
Jimmy Wu
We have a new build out that will fix this issue. It should be out soon, but if you can't wait, let me know and I can open a backend ticket and send it to you.
victor367017
Error with CS5
Yes send it to me. I am in the process of updating my menus my site is not working as it should be
Jimmy Wu
I have opened up a backend ticket for you and will send you the download shortly. To check your backend tickets, log in to your account at www.webassist.com and check your support history.
john143153
Error with CS5
I have the same error writing menus using CS5 - it was fine using CS3. Please can you send me the link to update CSS Menu Writer. Thanks
The currant version of menu writer, version 2.0.5 should fix this error, it is available from the download center.
Make sure you are using version 2.0.5, if you still have the issue, delete the dreamweaver cache file from the users configuration folder:
