Upload area needs to be re-directed to a thank you page
Thread begun 5/25/2010 5:57 am by bbgd | Last modified 12/02/2010 6:44 am by Jason Byrnes | 2333 views | 4 replies |
bbgd
I have an upload page and a progress bar. Both work properly. I would now like to have a "Thank You" page load to show a successful upload after the progress bar has finish . Can this be done?
You can do this using a server redirect. On your page with the upload go to server behaviors > webassist > utilities and select 'server redirect'. For the trigger select all uploads successful, then select your thank you page as the page to go to.
With this in place you will first upload the file and see the progress bar, then when the upload completes you will be taken to the page specified.
enquiry272230
Redirect Not Working
Using Dreamweaver CS 4, Universal Email 4
Testing file upload locally prior to going live.
Redirect does not work after file upload, either with the insert record behavior, and also after adding server redirect - all uploads completed.
The trigger is "Button Submit Pressed" for both file upload and insert record, and after the progress is complete, the page goes nowhere.
bbgd
Ya, what he said.
most likely a php error is occurring that is preventing the redirect.
add the following code at line 1 to turn error reporting on for troubleshooting:
error_reporting
(E_ALL):
please post back any errors after testing and a copy of your page in a zip archive.
