Pure Virtual Function Call Error
Thread begun 5/22/2010 6:25 pm by Miguel | Last modified 5/24/2010 10:14 am by Jimmy Wu | 1567 views | 1 replies |
Miguel
When applying the data assist wizard having selected result, insert and update selected if you add some fields menu then bind it to a table if you bind more than 2 menus to a same table it crash the system with an runtime error making me open the task manager to kill dreamweaver, we should be able to select the menus from a recordset we make or have an option ftom table or recordset (make recordset), i did this cause when i used addt i was able to select the same table for many menus and it added new records for each recordset_lvl1 recordset_lvl2, now why am i trying to use one table for many selects on the site im building i have many fields that ask how is your study level, how is your health, and so one and the awnsers are the same Bad, Poor, Good, Exelent... and instead of manually adding those to the menu they where selected from a recordset.
Im using DataAssist Beta release 2.0.7 Build 277 turning back to 2.0.6 just in case will report back if the same issue happens or not on 2.06
Jimmy Wu
We've run into this issue with a few other users and most of them were able to find ways to resolve the issue. Here's a link to a thread where other users' fixes or workarounds are listed:
showthread.php?t=2947
