Can you specify size options with a static cart?
Thread begun 5/22/2010 12:36 am by chriscaldwell11357847 | Last modified 4/11/2013 8:37 am by Jason Byrnes | 4237 views | 9 replies |
Forgive me, I'm new to this forum, and I really appreciate your help. This is the first time I've incorporated a cart with a site, and have questions about things as they come up.
I'm selling Tshirts and don't know how to specify the various size options. Prices are the same for all shirts. What is the most efficient way to do this?
My cart items are static (no database).
Thank you so much.
Chris
To add options to a static, you first need to add a column to the cart object for the option.
In the eCart object editor, go to the Columns section and add a new size column. Set it to be unique.
Now in the eCart Add to Cart button wizard, select the new size column and select the option to be editable from a select list.
This will add a select list to your page. you can then populate the select list with the available sizes.
Thank you very much for the help!
Chris
wow
It's amazing how cool this extension is. I'm so thrilled with this and with the instant help. I have never created an ecommerce site before and it was overwhelming at first, but with help on this forum, it is all starting to click. Thank you your patience and for not making me feel stupid! This product is great!!!!!!!!!!!!!!!!!!!
chris
Excellent, glad to hear you are getting it working.
info185511
Color options in a static cart
I have several items in a product page, two are items with different colors. Created a similar scenario as above replacing sizes with colors one has six colors other has seven. When testing with localhost the color and quantity work well for both these items and there is a redirect to the cart page. However if another product is selected I have these errors appear at the top of the page and there is no redirect to the cart page.
Warning: Missing argument 10 for NBA_eCart_Definition::AddToCart(), called in /Applications/MAMP/htdocs/NBA/products.php on line 27 and defined in /Applications/MAMP/htdocs/NBA/WA_eCart/NBA_eCart_PHP.php on line 28
Notice: Undefined variable: itemColor in /Applications/MAMP/htdocs/NBA/WA_eCart/NBA_eCart_PHP.php on line 33
Warning: Cannot modify header information - headers already sent by (output started at /Applications/MAMP/htdocs/NBA/WA_eCart/NBA_eCart_PHP.php:28) in /Applications/MAMP/htdocs/NBA/products.php on line 1474
You must have created this pages add to cart button before adding the color cart column.
When you add a column to the cart, you will need to edit any add to cart behaviors that have already been created.
open the server behaviors panel, double click the eCartAdd to cart server behavior, then click the ok button to have the code regenerated for the current columns.
info185511
You were right the color was added after. Once the code was updated every is working fine. Thanks for your help.
you're welcome.
