need help seting up user-registration
Thread begun 5/21/2010 2:36 pm by Lourenso389224 | Last modified 6/04/2010 11:31 am by Jimmy Wu | 3727 views | 7 replies |
Lourenso389224
Hi I got the user-registration and I dont know anything about my sql. I went to godaddy and I am trying to set up a table. I tried to follow your instructions but I am lost at the my sql step. I only got to step 1 and I am confused...don't know where to go from here. Can anyone help?
Jimmy Wu
GoDaddy should have provided you with an interface to use the databases, in this case, most likely PHPMyAdmin. So, you would want to skip the first page in the tutorial and just go directly to the Using PHPMyAdmin section and follow the steps there. If you are unable to follow those steps, please point out which step you're falling down on and I'll try to clarify it for you.
Lourenso389224
I am lost at the first step
Hi thank you for getting back to me. I am lost at the first step I went to GoDaddy's MyPHPAdmin and am trying to follow the steps but I don't know how to identify which .sql file I need to import.
Jimmy Wu
The file you need to import is the one located in the Database directory in the UserRegistration100 directory of your download. It is called users.sql.
Lourenso389224
1/2 way there
hi ok I am up to were I am trying to go live with the page but when I try the Registration link it keep sending me to a page with (Query was empty) I know I have to do something in line 45 and 47 my page is www.complexionmagazine.com take a look and let me know what to do
Thanka alot
Jimmy Wu
What is on lines 45-47? Did you make any changes to the registration page before uploading it?
Lourenso389224
Query was empty
hi I am geting a (Query was empty) when I try to go to the register page from the link
Jimmy Wu
Yes, I understand that that's the error you are getting, I was not asking what error you're getting, but about the code on the page. Can you attach the /register page/users_Registration.php page so I can take a look at it?
