Universal 4 not sending email
Thread begun 5/18/2010 4:39 pm by carl181913 | Last modified 5/27/2010 7:18 am by Jason Byrnes | 5055 views | 13 replies |
carl181913
I read the other thread and I have a similar issue were I have been using version 2 for a couple years and just upgraded. But the new version is not sending emails?
I uninstalled v2 from first before installing the v4 CS4
Here is the form I am trying to use it on:
contact.php
No errors but no email either?
carl181913
I uninstalled ver 2 from MX
This post has been deleted.
Please post a copy of your page so I can examine the code.
carl181913
here is the code
I have attached the code for the whole contact.php page. All the webassist files were uploaded to the server untouched.
Let me know what you find. thanks
your forms action is set to post to another page:
<form name="contact" method="post" action="contactSent.php">
this will bypass the universal email code and go directly to the contactSent.php page, do not pass go, do not collect $200.
Your forms action should be set to post to itself, or left blank:
<form name="contact" method="post" action="">
carl181913
still no work?
I have many sites using v2 with the form post going to another page and it works fine?
Regardless, I changed it so the form posts to itself and still not working?
It's not possible for Universal Email to send the email message if the forms action points to another page, unless you apply universal email to the other page.
In the universal email wizard, set the "Go to page" to the page you would Universal Email to redirect to after the message is sent.
If it is redirecting to that page, try leaving the SMTP server and port settings blank so the defaults in the PHP.ini file will be used.
carl181913
I am getting no where with this???
Jason,
Ok, I tried changing the form post as you requested and it does not work.
So to eliminate any other stuff that may be been on that page I used the Webassist CSS form builder to create a default contact page that postes to itself and then added the universal email to send me a simple email and it still does not work???
Here is the link to test and I have attached the code for this page:
testForm.php
If you submit the form something is missing that will not allow the page to reload. If I remove the universal email behavior it works fine. I have not changes any code. I started with a blank page and used all default Webassist software.
I also tried it with and without the port #.
when a page displays blank, it means a php error is occurring, but error reporting is turned off. Add the following at line 1 to turn error reporting on:
error_reporting
(E_ALL);
carl181913
I added the error code
I now get this error when I submit the form:
Fatal error: Call to undefined function: session_commit() in /home/virtual/site42/fst/var/www/html/testForm.php on line 79
