...Taxes depending on Zip Codes /Check out setup...
Thread begun 5/18/2010 12:48 am by Bruce | Last modified 11/04/2011 8:30 am by goat200487425014 | 10749 views | 40 replies |
Bruce
.........Taxes depending on Cities
I want to set the Tax up in checkout page.
  • Shipping is Free.
  • I only need to set the Tax up for different Zip Code of California state. I want, for example if a user shops from e.g. 90025 zip code and another user shops from e.g. 94102 zip code, eCart to calculate the applicable taxes depending on the zip code entered by users.
  • No tax for other states.
Theses are the requests from my client.
Can this be done in Check out Wizard?
If yes, can you please guide me to accomplish this.
Thank you in advance.
No, this cannot be done in the checkout wizard.
you will need to create a separate tax rule for each tax rate you need to apply.
the billing zip code will be stored in a session variable named "eCartCheckoutForm_postcode"
you can use the Based On session Variable value trigger in the tax rule:
If the session variable "eCartCheckoutForm_postcode" has a value "=" to "90025"
some of your zip codes may have the same tax rate, so they can be combined into one rule by adding another trigger and setting the OR seperator
Bruce
Not understand.
Hi Jason,
Thanks for your reply but honestly i have no idea about the session, variable...and these technical vocabulary. Unfortunately I do not know PHP and programming at this level. That's why I bought the eCart 5 because I thought it was ready out of the box. I would not accept this contract from my client if I knew there was a long learning curve behind eCart5.
Just I let you know I started to set eCart5 up since December 2009 and it's not yet finished. So I spent hours ,days and weeks...
Please do not take it personal but you should understand if we (customers) buy your products because we believe in your advertising and we think this is the right product out of the box.
Suggestion:
Please do more friendly and easy to understand tutorials about different steps. That way you do not waste your time neither ours.
I would appreciate it if you can guide me how to do this Tax step by step or if you have any tutorial regarding how to do it.
Help/Question
Please help me how to set up the tax for California.
Can you please guide me how to setup the Tax in eCart5 for California?
There are 4205 zip code and 14 different Tax Rate in California, how can I set up this?
Do I need to to set up tax rate for every county or city?
Thanks.
To be fair, what you are asking is not a standard request, and I don't believe you will find any cart system that will support this sort of tax calculation out of the box.
To accomplish this is going to take 4 main steps:
1) Create a tax rate table
2) Create a recordset to lookup the tax rate
3) Add a Set Session value to store the tax rate
4) Set the tax calculation to use the session value.
1) I think if you can break the tax rates up by city instead of zip code it would definitely simplify things, but either way, I think this solution is going to call for a new database table to hold the tax rate - zip code or city relation:
taxID - Primary Key column - Auto Number
TaxRate - Number - holds the tax rate
zipCode - varchar - holds the zip code - could be state if you decide to go that way instead
You will need to enter all of the zip codes and the corresponding tax rates into this table.
2) Then on the confirm page, create a recordset to lookup the tax rate from the database for the zip code that was entered.
To create the recordset, click the plus button on the server behaviors panel.
Set the name of the recordset to "taxLookup"
select the database connection to use, select the taxRate table.
Leave the recordset window in simple view.
In the Filtering section, Select the zipCode column set the comparison to '='
set the variable type to Form Variable and enter 'postcode' for the variable name.
3) Once the recordset is created, add the set session value server behavior to the confirm page.
Click the plus button on the server behavior panel and select eCart -> General -> Set Session Value
For the trigger select "Recordset taxLookup is not empty"
set the name to "taxRate"
click the lightning bolt next to value and select the taxRate column from the taxLookup recordset.
4) Now to create the tax calculation.
In the eCart object, on the tax tab, click the plus button to create a new tax rule.
For the trigger select Session variable Exists:
if the Session Variable 'taxRate' exists
for the calculation use Based on carts taxable subtotal:
Taxable subtotal 'Times' '$_SESSION['taxRate']'
Bruce
Set up only two Tax rate
This post has been deleted.
Bruce
Bruce
Jason,
Thanks for your explanation and I apologize for probably my not friendly post. I am under pressure to finish this job. Thank you for understanding.
Finally after hours of search and effort I could create a table with 1773 cities (CA) with their relative tax rates. I created 3 columns in this table,TaxID,City and Tax columns.
Now I need your help and assistance to go from there please.
Q1)
Should I add more column to this table? If yes, please mention which one and what to assign in Type in phpMyAdmin.
Q2)
Should I remove tax setup in PayPal (I've already set it up to 9.75%) and let eCart do the job?
Thanks.
Bruce
Need Help on "Tax Calculation".
I did all the steps you mentioned and I am stuck at step 4 in Tax Calculation page. I cannot get the corresponding Tax/City, no tax is added to confirm page. I am sure something is missing but I do not know what's missing. I include a snap shot.
Thanks.
Bruce
Help on Tax Calculation
Any help in Tax Calculation?
Please see above post with screen shot.
Thank you.
Did you create the record set to lookup the tax rate form the database?
Is it setting the tax rate in the $_SESSION['taxRate'] correctly?
Add the following to your confirm page to see if it is being created gorrectly:
if(!session_id()) session_start();
echo
"tax rate: ".$_SESSION['taxRate'];
if the recordset is working properly, this should show the tax rate.
In the screen shot, you have not entered a name for the session variable, nor have you entered anything to multiply the taxable total by.
For the trigger use:
session variable exists:
if the session variable 'taxRate' exists.
