Add multiple items to cart form PHP loop.
Thread begun 5/16/2010 4:09 pm by kevin347925 | Last modified 5/17/2010 9:11 am by Jason Byrnes | 2879 views | 1 replies |
kevin347925
Hello. I want to add multiple items to a shopping cart by posting form variables. I have looked at the tutorial for how to do this from a recordset, but what I have set up is a bit different. I have set up a loop based on image files is a specific folder. The loop is within a form that displays each one of these images with a checkbox under it. I would like to post those form variable into the shopping cart. Again, I am not using a DW or WA recordset to display this data.
Does anyone have any advice for me? Thanks so much.
you would need to hand code a recordset that will take the ID value that is posted from each checkbox to return all of the selected products. Then use the eCart Get Contents from recordset behavior to popu;ate the cart.
We really cant offer a lot of support for this if you are not using Dreamweaver recordsets, or DataAssist
