php syntax again
Thread begun 5/09/2010 8:30 am by info406008 | Last modified 8/23/2010 5:45 pm by MikeH | 4515 views | 7 replies |
info406008
php syntax again
Hi there,
I have exactly the same problem listed elsewhere on this forum- the content name and location are not generated in the developer notes.
E.g.
include('/home/sites/mysite.com/public_html/cms/WA_CMS/addtosite.php');
echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, '@@content-group@@', '@@content-ref@@', false@@order@@);
I have followed the advice given by Jason Byrnes here: showthread.php?t=12143
..but with no success.
It works fine on my MAMP testing server but as soon as I upload to the internet it fails.
I also tried reinstalling but again no success.
I'm uploading to a Linux server on Heart Internet.
Any help MUCH appreciated!
login.php
MikeH
Just found this post Im on the same host Heart Internet and it does not work for me either.
Never had a problem with any solution or extension in the past with this host always been very good.
Mike
In the Download Center for PowerCMS, there is a known issue fix for this problem.
Please log into the download center and go to the PowerCMS section, then look in the Known Issues section.
MikeH
Hi Jason
Tried that already same problem.
Just get all the code like this:
........... deleted the rest : '@@content-group@@', '@@content-ref@@', false@@order@@
So a little lost now.
Mike
MikeH
Jason something I have noticed is in firefox it gives some details of errors:
Error: missing ; before statement
Source File: Fuel.php.js
Line: 1, Column: 2
Source Code:
(8)Exec format error: exec failed (Fuel.php.js)
IE (latest)
Webpage error details
Message: Expected ';'
Line: 1
Char: 4
Code: 0
URI: Fuel.php.js
Line: 1
Char: 4
Code: 0
URI: Fuel.php.js?1282572272124
Not sure if that helps.
Mike
MikeH
---Alos posted this in another thread about the same problem---
Right looks like its very simple to fix I have done a few tests and all seems to be working prefect so far (fingers crossed).
1. Outside Dreamweaver rename Fuel.php.js to fuelphp.js
2. Inside dreamweaver do a find/replace on all local files (7 instances should be found)
find Fuel.php.js
replace with fuelphp.js
Upload the changed files and test
I have found it works in all browsers with colour highlighting and the correct link now shown in dev notes.
I hope this helps some of you who are stuck too.
Mike
