'@@content-group@@', '@@content-ref@@', false@@order@@
Thread begun 4/13/2010 10:03 pm by neilo | Last modified 8/16/2011 7:58 am by Jason Byrnes | 18477 views | 35 replies |
neilo
Hi Guys,
Have installed CMS2 to my testing site, using a template, and adding code to a page created from that template.
Installation went smoothly, except that once the page is added (it has eight editable areas to which the developers' notes need to be added) each of the developers' notes is the same:
include('/home/users/uks66584/html/yahoodie.co.uk/CMS/WA_CMS/addtosite.php');
echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, '@@content-group@@', '@@content-ref@@', false@@order@@);
This means that I can't view the page (error message: "Parse error: syntax error, unexpected '@' in /home/users/uks66584/html/yahoodie.co.uk/index.php on line 25).
Have closed the site, reopened it and gone back to the Admin section, selected the page and checked each area's developers' notes again. They are still the same.
How can they be made specific to the allocated areas, - should I be adding some code by hand?
Hmmm, that's an interesting one.
I am not able to reproduce this, the developer notes for my installation are generated correctly, for example:
include('/Applications/MAMP/htdocs/pcms2/WA_CMS/addtosite.php');
echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'site page', 'footer', false);
the developer notes code should be specific to the page already. Just out of curiosity, what are the names you are using for Content Area and Content Location?
neilo
Hi Jason,
Thanks for taking a look at this. All of my areas are on the site index.php so all are 'Content Location: Home Page'. Here is the full list:
Content Area: Feature Panel Heading
Content Area: Feature Panel Text
Content Area: Footer
Content Area: Header
Content Area: Left Frame
Content Area: Main Content
Content Area: Right Frame
Content Area: Sidebar Content
While compiling this list, I have just noticed that while all the Content Area descriptors show correctly in admin/index.php under "Choose the content area you wish to edit below" and in admin/contents_update.php in the 'Currently editing' line, the Content Area title, 'Feature Panel Heading' is curtailed by three characters where it shows in the contents_update.php immediately to the left of the 'Cancel' Button. There it reads, 'Feature Panel Head'.
It is also the first in the list. Perhaps I have exceeded a limit?
Cheers
the developer notes are dynamically generated using javascript.
In FireFox, go to Tools -> Error Console to see if a javascript error is occurring to throw things off.
login.php
neilo
Many thanks, -I have provided as much detail as I could think of.
chris.serendipity282254
Power CMS 2 error
I have exactly the same problem - upgraded a client site to CMS2 and now can't add anything!
Parse error: syntax error, unexpected '@' is the error message & this is ewhat the code generated is:
include('REMOVED/powercms/WA_CMS/addtosite.php');
This is a real time waster - how do I revert to the previous version of Power CMS?
I have a client getting really difficult now!
Quite a few errors in error console - e.g.
Error: missing ; before statement
Source File: Fuel.php.js?1271289550293
Line: 2, Column: 3
Source Code:
<b>Parse error</b>: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING in <b>removed/karoo/powercms/js/lighter/Fuel.php.js</b> on line <b>64</b><br />
in the js/lighter/Fuel.php.js file, change line 64 - 65;
start: this.strictRegExp('<?php', '<?=', '<%', '<script language="php">'),
end: this.strictRegExp('?>', '%>', '</script>')
to:
start: this.strictRegExp('<'+'?php', '<'+'?=', '<'+'%', '<scr'+'ipt language="php">'),
end: this.strictRegExp('?'+'>', '%'+'>', '</scr'+'ipt>')
Your server is configured to process any page with .php in the name as a php page, most servers will only process pages that end in .php as php code
Ny France
Power CMS 2 "Syntax error"
Hello Jason,
I change the code in Fuel.php.js but nothing happens.
Ny France.
after making this change, it will generate the developer notes with the correct syntax.
you will need to get the new developer notes and replace the previous developer notes.
Ny France
Hi Jason,
I am sorry but i don't understand what you mean "to get the new developper notes".
Can you to be more clear, thanks.
Ny France
