Survey Security
Thread begun 5/06/2010 10:10 am by mrobben375515 | Last modified 5/06/2010 10:26 am by Jimmy Wu | 1225 views | 1 replies |
mrobben375515
Survey Security
I'm creating a survey that I want to only be available to users one time. Right now, a single user could take the survey as many times as they want and jeopardize the results so I need to have a way to keep that from happening. I think the best ways are to have a ISP address check or email field that doesn't allow users to enter the same email. Please let me know what is the best way to make this happen. If I go the email route, I need to make an email form field that checks with the database table attached to the form to see if that email address has already been entered. How do I do that? Thanks for your help...
Jimmy Wu
Neither checking the IP or comparing with values in a database are built in to Form Builder and you will have to custom code it by hand. I can give you some steps you can take to accomplish the behavior though. To check the email, when the form is submitted, on the page the form posts to, you would want to have a recordset that would query the database for that email address. Then if the recordset is not empty, you will want to forward the user to a failure page notifying them that they can only fill out the survey once. Make sure that this is before the code to insert into the database.
For the IP, you would have to get the IP and before the form loads check if the IP is stored in your database already in the same way you check for the email address.
