Alternate styles in rows
Thread begun 5/05/2010 4:55 pm by danny405167 | Last modified 3/22/2011 8:14 pm by Lon Winters | 1960 views | 2 replies |
danny405167
I would like to know if there is a way for alternating the colors in a row table? The only post that I found is the one below but it was not helpful. I follow the suggestion in creating a dataassist results page and then copy and paste the code but I did not find the code under the repeating PUBLIC table. Do I have to create an ADMIN result page for the code to get written and if so, is there a way to change the alternating colors?
I noticed that datassist has a repeating table button that has an option for alternating the row colors. I have tried using it but it does not display my result. Is there a tutorial for datassit repeating table?
This is the post that I found
Apply Alternate Styles to Current repeating region
This is the code that datassist wrote for my PUBLIC result page (repeating table)
<table id="WADAResultsTable" border="0" cellpadding="0" cellspacing="0">
<?php do { ?>
<tr>
<td class="WADAResultsEntry"><div class="WADAResultThumbArea"><img class="WADAResultThumb" border="0" src="images/<?php echo $row_WADAcl_items["img"]; ?>" alt="Image Name" /></div>
<div class="WADAResultInfoArea">
<div class="WADAResultTitle"><?php echo $row_WADAcl_items["itemID"]; ?></div>
<div class="WADAResultDescription"><?php echo $row_WADAcl_items['itemTitle']; ?></div>
<div class="WADAResultCommerceArea">
<div class="WADAResultCommerceButton">[ button ]</div>
<div class="WADAResultPrice">$49.95</div>
<div class="WADAClearRight"></div>
</div>
</div></td>
</tr>
<?php } while ($row_WADAcl_items = mysql_fetch_assoc($WADAcl_items)); ?>
</table>
The alternating colors relies on some php code, the alternate color style being defined, and setting the class to the code that alternates it.
You should start with a page that has a working repeating region that is applied to the tr. From here you can add in this code to the top of the page:
//WA AltClass Iterator
class WA_AltClassIterator     {
  var
$DisplayIndex;
  var
$DisplayArray;
  function
WA_AltClassIterator($theDisplayArray = array(1)) {
$this->ClassCounter 0;
$this->ClassArray   $theDisplayArray;
  function
getClass($incrementClass)  {
    if (
sizeof($this->ClassArray) == 0) return "";
      if (
$incrementClass) {
      if (
$this->ClassCounter >= sizeof($this->ClassArray)) $this->ClassCounter 0;
$this->ClassCounter++;
    if (
$this->ClassCounter 0)
      return
$this->ClassArray[$this->ClassCounter-1];
    else
      return
$this->ClassArray[0];
?><?php
//WA Alternating Class
$WARRT_AltClass1 = new WA_AltClassIterator(explode("|""WADAResultsRowDark|"));
Next you will need to add in the style into the head section like this:
<style>
.WADAResultsRowDark {
background-color: #DFE4E9;
</style>
Finally you need to locate the <tr> that is repeating and apply the following class to it so it looks like this:
<tr class="<?php echo $WARRT_AltClass1->getClass(true); ?>">
You can change the alternating color based on the background color in the style.
Lon WintersBeta Tester
Thanks to the OP who worded the title correctly, made it come up readily when I searched the topic.
I was able to apply this code to a page that already had both a Repeating Table and Repeating Region - worked great.
