absolute path for images
Thread begun 5/05/2010 1:37 am by 27100169 | Last modified 5/05/2010 11:54 am by Jason Byrnes | 2988 views | 5 replies |
27100169
I wish the pictures that I insert HTML editors have an absolute path.
I read this: showthread.php?t=10817 and so I changed the file HTMLEditor\editor\filemanager\connectors\php\config.php like this:
// Path to user files relative to the document root.
$Config['UserFilesPath'] = 'http://www.2727.eu/dbase/';
$Config['UserFilesPath'] = $EditorAssumedRoot.$Config['UserFilesPath'];
// Fill the following value it you prefer to specify the absolute path for the
// user files directory. Useful if you are using a virtual directory, symbolic
// link or alias. Examples: 'C:\\MySite\\userfiles\\' or '/root/mysite/userfiles/'.
// Attention: The above 'UserFilesPath' must point to the same directory.
$Config['UserFilesAbsolutePath'] = '/workdisk/home/web/000139-2/www.2727.eu/htdocs/dbase' ;
if (isset($_SERVER['APPL_PHYSICAL_PATH'])) {
$Config['UserFilesAbsolutePath'] = str_replace("\\","/",$_SERVER['APPL_PHYSICAL_PATH']) . substr($Config['UserFilesPath'],1);
with these changes, however, the images still have a relative path.
sorry for my english
changes to the javascript files often are not picked up by the browser very quickly.
you may need to clear the browsers cache to force it to see the new javascript changes and use them.
I clear the browsers cache in Internet Explorer, I also installed Google Chrome to try a different browser, but the result is the same.
try changeing:
I tried this:
//$Config['UserFilesPath'] = $EditorAssumedRoot.$Config['UserFilesPath'];
but the path is not absolute; of course, before I deleted the browser cache
login.php
