IRite Image URL
Thread begun 3/03/2010 5:49 pm by ideasbyjr63389 | Last modified 3/04/2010 3:25 pm by Eric Mittman | 2808 views | 3 replies |
ideasbyjr63389
IRite Image URL
How do I assign and automatic value for the image to show URL address in front of the image path. ()current image path on image property window.
If you are doing this in iRite you should be able to get the full http prefix for the image by adding the http info in this setting:
$Config['UserFilesPath'] = 'http://mywebsite.com/current/' ;
This setting is in the file WA_iRite > editor > filemanager > connectors > php > config.php
ideasbyjr63389
New error
When I make the changes I get the error shown in the attached images
My setup looks very similar except that I also have the user files absolute path specified. For mine I have it set to the file system path to this folder. If the file system path is the one specified in the error then you should be able to use a value like this:
\nawinfs02\home\users\web\b908\rh.apr2008clients
I can get a similar error if I do not have both paths set accordingly. If this is not the file system path to this folder then you will need to get that first, and use it for this setting.
