Power CMS2 MySQL db not working on new domain
Thread begun 5/04/2010 3:15 pm by peter348932 | Last modified 5/05/2010 6:58 am by Jason Byrnes | 2203 views | 3 replies |
peter348932
I have been using PowerCMS 2 with a website for the last week, now I have transferred all files to the new domain but still using the same MySQL database.
when I access it from the old domain it works
when I try and access it from the new domain it tries to set up a new connection to the database and then complains the tables are already there. - I know they are already there.
why does it think it a new connection . and how can I can it to work with deleting everything?
i,e what do I need to do to make the new domain simply use the database without trying to set up new tables?
thanks
peter348932
I should point out the accessto the database from the new site works and so the website can disaply the content
its only whan I go to login it tries to set up a new connection and then complains there is already a database there
if I log in from the original doamin it works.
how can I fix this ?
peter348932
found it
ok - I did some digging and found there is a folder created in powercms called "connections"
on the website and does not exist on the local machine that created the website...this needs to be copies to the new domain and then its working....
OK, glad to hear you got it working.
