phpmyadmin not found
Thread begun 4/29/2010 9:52 am by rmtoelle346587 | Last modified 4/30/2010 3:50 pm by Jimmy Wu | 4277 views | 5 replies |
rmtoelle346587
I am in the process of transferring everything from test server to actual base server, when I try to log into the XAMPP admin I get a big black NOT FOUND, it switched urls from hhttp://localhost/phpmyadmin/ on my test server to hhttp://mail.dentalsysteminstegrators.com:3000/phpmyadmin/ (I added the extra "H" for this post only) on our main server, which is also our email and webserver, I am not the admin, and have not talked to him yet, I am supposed to be doing this on my own, maybe you can help me>? I had everything working great on my test server except the PayPal, which we are still getting verified, and FedEx which I will deal with after I get the main site up again... thanks
Jimmy Wu
I'm not sure you can just transfer your xampp install over, you may have to install that on your server as well. You might want to contact xampp support to take a look at this issue, since it seems like that's what the issue is.
rmtoelle346587
myphpadmin NOT FOUND
I installed XAMPP on the root drive of the main server, I used the same installation process as I used on the test server, I extracted cURL to the htdocs folder in XAMPP, changed the PHP.ini file so cURL configures correctly, extracted PowerStore3 to the XAMPP/htdocs/PowerStore3 directory, just like Jason from WebAssist advised me. Then I run XAMPP control panel and start the mysql service, which connects fine, but when I click on the ADMIN button I get the error. NOT FOUND.... does that help???
i.edwards384429
update
Hi
are you talking about installing WAMP on your webserver?
If so I seem to remember somewhere that it wont work as most servers use server technology and WAMP is designed to go on workstations to emulate a live server
HTH
Ian
rmtoelle346587
it called XAMPP, not WAMP, I AM STUCK NOW!!!!
At the moment there are four XAMPP versions:
* a version for Linux systems (tested for Ubuntu, SuSE, RedHat, Mandrake and Debian),
* a version for Windows 2000, 2003, XP and Vista,
* a beta version for Solaris SPARC (developed and tested under Solaris 8),
* and a beta version for Mac OS X.
So why doesnt XAMPP phpadmin run like it did on my Vista Machine? XAMPP control panel works fine, SQL service runs, then when I click ADMIN it says... NOT FOUND
I really need you big boys to scratch your heads and say what I need to hear..
We are running W2k3 server R2 Standard 32bit OS. The server is being used as an email server, and we host websites on the same server, this should not be a big mystery that you have never seen I wouldnt think. Please help I have put too much time and effort into getting this PowerStore3 up and running to quit and ask for a refund now.
Jimmy Wu
As I said before, this is an issue with XAMPP, not PowerStore, so you should go to XAMPP and ask their support what is happening. That would be the best place for you to get help on this issue.
