Hiding the infowindow (address bubble)
Thread begun 4/27/2010 7:11 am by bkmorgan340383 | Last modified 4/29/2010 3:55 am by Heckie | 3960 views | 4 replies |
bkmorgan340383
Is there a way to hide the address bubble callout in a map?
I have a small map and would like to display only the map and pushpin.
Jimmy Wu
Here is a link to a forum post with instructions on how to get the info window to not pop up:
showthread.php?t=1183
bkmorgan340383
Re: Hiding the infowindow (address bubble)
Would you be so kind as to look at:
wagmp_map_9.js
and tell me which of the lines to comment out? I can't get it to work. I'd really appreciate it.
The marker_0.openInfoWindowHtml code is on lines 180, 187, 208, 215 and 231.
I want to show the map and the push pin, but not the address call out dialog balloon.
Originally Said By: Jimmy Wu
each instance that comes after:
GEvent.addListener(marker_0, 'click', function() {
should be left alone, that will be the one used if the pushpin is clicked.
if('address_0' == 'address_0')
should be commented.
Heckie
I could only get this to work by commenting or deleting the following lines:
// if('address_0' == 'address_0')
// marker_0.openInfoWindowHtml(address_0.infowindowtext);
example: 2010/
