Removal of Info Window - OLD SOLUTIONS not working
Thread begun 5/21/2009 1:19 pm by nathan125991 | Last modified 5/21/2009 2:45 pm by nathan125991 | 7149 views | 6 replies |
nathan125991
I cycled down too. I bought Google Pro Maps today and I'm trying to prevent the infowindow from popping up.
I don't have any extensive .js files associated with your other solutions. It appears that the solutions are scripted in PHP.
What is the PHP method for commenting out the INFO window, or toggle it to OFF until someone hits the peg?
Nathan
You could comment out the openInfoWindow() function call in the .js code. It should be very similar to before. Do you have a sample url I could tell you the exact line.
nathan125991
link to page
locations.php
There's only a few lines in the .js file. The other files are written in php.
Also SPRY breaks the heck out of the google map api. I'm having to search for a different tooltip atm.
If you look at the code you will see code similar to:
GEvent.addListener(marker_0, 'click', function() {
marker_0.openInfoWindowHtml(address_0.infowindowtext);
if(!fromAddress.enabled || 'address_0' != 'address_0') {
map.setCenter(point, 13);
map.addOverlay(marker_0);
in the line after the addOverlay line, comment out the openInfoWindowHtml line... like:
// marker_0.openInfoWindowHtml(address_0.infowindowtext);
nathan125991
There are three sections of code with lines like that. I commented the lines you mentioned in all 3 spots. I still get the infobubble.
You commented out the wrong ones.... look at my example... you now have:
when you should have:
nathan125991
THANK YOU THANK YOU THANK YOU.
It worked.
But then again, you knew it would. Thank you.
