no region at this zoom level
Thread begun 4/23/2010 5:51 am by bryonyjayne405948 | Last modified 4/26/2010 12:31 pm by Jason Byrnes | 2783 views | 3 replies |
bryonyjayne405948
I've just installed this extension to work with Dreamweaver CS4, pretty new to all the software I'm using.
I followed all the steps to add dynamic data from a MySQL database. The map placement image comes up in design view. Then I click on Live view, and Preview in browser and an grey box appears where the map should be. The pins for the locations show, but no map.
There is small print across the grey box that reads: 'Im sorry but we don't have maps at this zoom level for this region, try zooming out for a broader look'
Which I do - and nothing.
I've tried adding static addresses, differnet default views, I've tried it on completely empty PHP pages, I've tried moving the line of code:
<script type="text/javascript" src="google_javascript/wagmp_maps.js">/*wagmp*/</script>
right to end, just before...
</body>
</html>
I've tried different formats for the addresses, and addresses from America, UK and south Africa.
Not sure what I'm doing wrong.
What I want to use it for, is to display dynamic data from a database that receives information from a html form. So that new 'pins' can be added to the map by users.
The pins will need to be one of 10 different coulours.
Is this possible? (provided I get past the first hurdle!)
Any help would be muchly appreciated, but please keep it simple, its already so complicated! Thank you!
love and light
please post a link where we can see the page to investigate the cause of the problem.
bryonyjayne405948
I've been testing on localhost,
I've tried since to get it to show, and with some addresses it works fine, it's seems to have trouble recognising certain locations. The locations come from a database that is added to by users through an html form. Is there a way to ensure these are acurate enough to locate on the map?
I've also been trying to change to the design/colour of the markers-is this possible?
Thank you!
there realy is not a way to 100% guarantee that the addresses being added to the database are accurate enough for the Google amp API, but you can get close using server side validation available in CSS Form builder.
you could add alpha numeric validation to the street form element, zip code validation to the zip form element. This way you can limit bad characters being added. It wont guarantee that google can find the address though.
