Cannot install MenuWriter 2
Thread begun 4/21/2010 3:17 am by jth370895 | Last modified 4/28/2010 3:03 pm by Jimmy Wu | 3672 views | 5 replies |
jth370895
Hello Mr. or Mrs.
I used to work with MW 1.0.4! Recently I bought MenuWriter 2.0.3. When I install this version with Adobe Extension Manager CS4 everything works fine and Adobe tells me that MW 2 is installed correctly. But after starting Dreamweaver CS4 version MenuWriter 1.0.4 appears!!
When I remove the Menuwriter extension complete with Abobe E.M., after starting DW CS4 still the Menuwriter 1.0.4 appears and can be used!!!
How can I remove MW 1.0.4 in order to install MenuWriter 2? With Adobe Extension Manager this seems impossible!
Thanks for your help, I hope.
With kind greeting, Jan-Theo Weeda
Jimmy Wu
The Configuration folder may have been corrupted. Try renaming the configuration folder and see if that resolves the issue. Here is a post that goes over how to do that:
showpost.php?p=12293&postcount=2
jth370895
Thanks Jimmy
The first part of my problem is solved. But now the second: After removing MW 1 I installed Menu Writer 2.0.3. The Adobe extension manager tells me the CSS MW extension is correct installed. However, when I open Dreamweaver there is no Webassist Menu Writer in the Insert menu or toolbar, and also not in the help button! I tried it for three times, but without succes. How can I make CSS Menu Writer 2 get working?
Thanks en greet from Jan-Theo
Ps I work with Windows 7 and the Dreamweaver program works correct!
jth370895
Please answer my question above!
Hello Mr. Jimmy Wu or other technical engineer.
I Hope you will answer my guestion above as soon as possible, because at this moment I can not use Menuwriter, version 1 or 2, anymore.
Thanks anyway. Jan-Theo
Jimmy Wu
I have opened a backend ticket to get some additional information from you. To check your backend ticket, please log in to your account at www.webassist.com and check your support history.
Jimmy Wu
We were able to talk on the phone and determined the issue being that the install was going to a nl_NL directory instead of the en_US directory, so copying over the configuration from the nl_NL to the en_US directory caused the menu items to show up.
