Address displays in wrong location on map
Thread begun 4/19/2010 2:21 pm by Green Apple | Last modified 10/25/2010 11:06 am by Jason Byrnes | 2470 views | 3 replies |
Green Apple
When I typed in the address to maps.google.com the push pin was located about a mile off (same place as Pro Maps). We contacted Google and they have corrected the location so now when anybody types in the address the push pin is correct.
The same address used Pro Maps shows the push pin located about a mile away in the old spot. What can I do to ensure Pro Maps is using the same / latest info as maps.google.com?
Boston Chapel Christian Church, 29015 Boston Chapel Rd, Girard, IL 62640
map.asp
Jimmy Wu
The reason it is showing the incorrect file still is that we created a cache file to prevent the need to connect to google's server to get the geocode values each time. If you delete this file, it will be created again with the correct values once you've visited the page again. The cache file is located here:
_promaps_geocache.xml
ew391940
contacting google
How did you contact google? I think i am having an similar issue. I tried clearing my cache but my pushpin is not only a mile off but a few states off. My address is clearely in Colorado city, stat and zip but the push pin is showing up in Texas?????
How do i fix this?
The address is this
1 K RANCH RD
DINOSAUR, CO 81610
when i go to google maps they cannot locate the street address (its in a rural area) but it does put the pin in DINOSAUR, CO 81610 which is fine by me. But in pro-maps it is putting the pin in texas instead of on DINOSAUR, CO 81610. How do i fix?
you can contact google here:
businessCenter?hl%3Den%26gl%3Dus&hl=en
