Multiple Records Insert issue
Thread begun 4/19/2010 2:58 am by Douglas.DeAvila403969 | Last modified 4/20/2010 11:10 am by Douglas.DeAvila403969 | 2698 views | 5 replies |
Hi...
I'm following your "Inserting Multiple Records" how to document. I have a form with a header row, form elements row and submit button on a php page. I managed to follow the instructions on pages 1-2 to define a repeat selection. However when I move to add the multiple records server behavior by clicking the + sign from the Server Behaviors panel (Data Assist->Insert->Multiple Records Insert) I get the following error from Dreamweaver CS4:
"Your page must contain form elements in a repeating region to use this interface"
I'm not sure what I'm missing from the table...
Thanks!
Douglas
CraigRBeta Tester
just a thought, do you have a text field in your form elements row ?
can you send a copy of the page so we can examine the code please.
File with issue
Attahced you will find the file...thanks!
Douglas
CraigRBeta Tester
on lines 66 and/or 67 you need to have a text field.
if you add a text field, the insert record server behavior will work
It works...
Thanks a lot...it is working fine..I forgot to include the text fields in the table...my apologies for bugging you with this...Have a good day!
Douglas
