Need to undelete content
Thread begun 4/13/2010 8:46 pm by JMcKay400963 | Last modified 4/16/2010 8:17 am by Jason Byrnes | 1786 views | 3 replies |
JMcKay400963
Can you please give me the steps to un-delete content. I modified a store and turned it over to my client who then accidentally deleted the main content under support. I am unfamiliar with databases really, I only know enough to get myself into trouble. Hopefully you can get me out of trouble. Thanks
Deleting content is final, it cannot be reversed.
When content is deleted, it is completely removed from the database
the only possibility for retrieval would be if the host had performed a backup of the database.
JMcKay400963
OK, The user deleted a content section from the CMS. And there is no way to retrieve it?
I think I know the answer to this but.....
When you click on the support link in the navigation it goes to a page that looks like the template but the content is blank. I can't add that content back?
I did find in the database the history of them deleting it. Is there something to look for in the database that may restore it or show it is not permanently deleted?
I know I can manually add content to the PHP file but this won't be accessible through the CMS.
you can certainly create a new content area with the same name as the one that was deleted to recreate it.
PowerCMS will record the action that was taken, but the content is not stored in the database when it is deleted.
when you delete a content area, that content area is completely removed form the database.
