display product status on clients details page
Thread begun 4/13/2010 8:56 am by mr hankey | Last modified 4/16/2010 1:53 pm by mr hankey | 3698 views | 6 replies |
mr hankey
hi,
i have been trying and trying to get this to work and i know it will be something simple.
i have created my clients detailspage with data assist and i am trying to display the product status for that client on the page.
i looked at the recordset created by data assist which includes these parameters:
ParamClientID
Numeric
-1
$_GET['ClientID']
ParamSessionClientID
Numeric
-1
$_SESSION['WADA_Insert_clients']
ParamClientID2
Numeric
-1
$_GET['ClientID']
when i try using this with my recordset i get nothing displayed on page even though there is a status for that product to that client.
my recordset:
SELECT *
FROM product INNER JOIN clients ON clients.ClientID = product.clients_ClientID
WHERE ClientID = ParamClientID OR ( -1= ParamClientID2 AND ClientID= ParamSessionClientID)
no errors when i test this and no data when i click test button which is what i expected.
i have a productstatus column which i dragged onto my page next to a field that said "Status" but nothing displays for that client.
can someone help me please?
many thanks
Jimmy Wu
Have you tried running through the query directly in your sql database? If you haven't give that a try to see if any results are being returned. If not, then it may be caused by the recordset query not being written correctly.
mr hankey
hi jimmy,
i cant run this through mysql direct as the sesion variables etc are php variables generated by data assist.
they are the ones that come were generated from the details page so i copied them and tried with this recordset.
can you help with the recordset so it shows that product status for that clientid?
many thanks
Jimmy Wu
Try displaying the ParamSessionClientID and making sure that the value is set correctly. There might not be any results returned since the session variable is not set correctly. Also, you can replace the session variable with a hardcoded value to test it directly in the database. Give that a try.
mr hankey
hi jimmy,
i will give that a go.
many thanks for your help
Jimmy Wu
Let me know how it goes.
mr hankey
will do jimmy thanks for your help
