Update sql error
Thread begun 4/09/2010 11:49 am by fredalva299199 | Last modified 4/14/2010 2:41 pm by Eric Mittman | 3022 views | 5 replies |
fredalva299199
Update sql error
Hi, i am trying to use dataassist but i've got sql error
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '@company.comundefined, `nom` = , `prenom` = , `cp` = , `city` = , `country` = , ' at line 1
i try to find problem but no success, i am using last datassist release and Cs4
You can find database table and update.php file in archive file, thanks to help me to solve my problem.
Fred
On line 56 of your update page you have some of the column types values set like this:
$WA_columnTypesStr = "undefined|undefined....
When you edit the update server behavior that is on the page go to the columns and the values for them and check on the data types that are listed here. Make sure that you set them appropriately for the type of data that is in those columns. This should fix up the error you are experiencing. Please post back and let us know if this does not clear up the issue, post back with the updated version of this page as well.
fredalva299199
Hi, problem still occure.
I don't understand if i choose all types as textfield problem must be solved no?
and i still have same error:
Notice: Undefined offset: 1 in C:\wamp\www\site6\WA_DataAssist\WA_AppBuilder_PHP.php on line 135
Notice: Undefined offset: 2 in C:\wamp\www\site6\WA_DataAssist\WA_AppBuilder_PHP.php on line 136
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '@company.comundefined, `nom` = undefinedfredundefined, `prenom` = , `cp` = , `ci' at line 1
I have made an update to the page to see if it will let you get past this issue. When you are setting up your update on this page what steps are you taking when you are setting the data types for the info you are updating?
Please post back with as much detail as you can so that we know how to proceed. From what I can tell you still have many of the columns set as undefined for the types array. This can cause a problem because if the data is not declared as the proper type then it will not be quoted properly. This is the reason you are getting the current error regarding the email address. If it were contained in quotes you would not get this error.
The code that sets the quotes around the value is based on the column types string variable. If the values are not set correctly here then things will not work properly. Please post back and review the steps you are taking when setting the data types, some screen shots might help.
fredalva299199
Hi, problem still the same with your file.When i setup update file i choose all files as textfield exept user_id as text. There is no way like dreamweaver wizard to setup numeric fields.
(See attachment file)
to test if problem coming from my host,i created an update page using dreamweaver update wizard core and it's work fine(see profil_update.php).
Fred
I have opened a ticket for you on this issue so it can be looked into further. To update the ticket or check it's status login and visit your support history.
