Only 1 MRT data inserting
Thread begun 4/04/2010 9:54 pm by Russell Collins | Last modified 4/09/2010 5:15 pm by Eric Mittman | 3150 views | 10 replies |
Russell CollinsBeta Tester
I'm having a problem using more than 1 MRT on a page.
I can only get the data from no more than one MRT inserting.
I have the redirect url set to the last instance of the mrt but make no difference.
It seems only the MRT behaviour with the redirect applied is the one that will insert.
Any ideas ?
Regards
Russ
Are the triggers all set the same way? What happens if you comment out the last one and specify a redirect on the next one up? If the triggers are the same the other ones should be firing. If you comment out the last one and put the redirect on the second to the last one it should let you know if it is being triggered independently or not.
Here is a test page with problem
Hi Eric,
Here is a page I have been testing, only the second instance inputs.
Regards
Russ
Thanks for the file, it looks like you have the same trigger for both of these MRT server behaviors. I did not see a redirect for either one of them though. What happens if you specify different redirects for both of these server behaviors? Just looking at the code on the page I'm not sure why one would be working but not the other. To test it out I would need a copy of your db as well.
Have you tested this with the different redirects and commenting out one then the other? Please post back with what you discover and the results you are getting.
2 mrt's into the same database
Eric,
Should 2 MRT's applied to the same page be able to insert into the same database ?
Regards
Russ
Yes, you can have more than one MRT on a single page and have both of them insert into tables in your db. Were you able to discover anything by testing out the MRTs' on the page? If you are only getting records inserted into one of the tables there must be something on the page that is preventing the other one from triggering, or makes it look like it it not triggering. If you test one then the other you should have a better idea about how it is currently working.
same table
Sorry Eric,
i was meant to say into the same table of a db
Russ
Here are my testing pages & db
Hi Eric,
here are my testing pages and db.
I have place a session variable bound to the contactID on the insert form as a substitute for the idPEOPLE session variable from the main table I'm using in my main system.
I'm at a complete loss over this now.
I am wanting to manage 3 address per contact.
Maybe I'm attempting this this the wrong way.
Regards
Russ
Thanks for posting back with that, it is very helpful. I was able to craft a page almost just like yours and here is what I have found.
If you have the same $WA_masterKeyValue set for both MRTs then it will only do one of them. I was able to reproduce this and confirm the result. The way around this was to use a different id for the $WA_masterKeyValue in the second MRT and it worked like I thought it should.
I'm not sure that I fully understand what you are trying to accomplish as an end result with the data in the pages that you posted, but if you are only adding records for a single contact then you should only need to have one MRT. You should only have mutiple MRTs if you have multiple master key values to manage with additional records.
Additional tables
Thanks for that Eric,
My idea was to be able to have 3 addresses for each contact, and manage those with the mrt insert, update.
So I understand now that is not possible if I use the same masterkey, that being the contactID..
Given that, should I add 2 additional tables to incorporate those extra addresses ?
or incorporate an additional relational table as in
1. contact has addresses
2. addresses has type
or some other way
Regards
Russell
